メインコンテンツにスキップ
2017年4月に発売されたSamsungの新しいフラグシップのスマートフォン、Galaxy S8です。
20回答 すべてを表示
Sim Card Tray Won't Eject
Hi There Everyone!
I’m having an issue with my S8, where my Sim card tray won’t eject from my device. Is there anyway to remove tray without having to open my device.
Thank You!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Gave up and decided to take it to a local repair shop. They manged to get it out by using a dental pick like this one (Amazon Link) and wiggling the pic around until it came loose. Apparently it broke inside the phone so i’ll need to purchase a new sim card tray but at least now i can install my sim card and micro sd card.
Hopefully this helps someone!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Totally, I read this and was like, don't use a dental pic. I ended up using a blunted (broken) felting tip from my sewing kit, but any non-pointy metal pick that is small/strong enough to fit in there would probably work. It's totally mechanical and not spring loaded, so it only slightly pops out. It's still enough to release the locking thing and let you get it out by hand.
TL/DR
blunted pin downward motion
さんによる
コメントを追加
回答を追加する
ZebaraZoomer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 41
今までの合計 14,389
