メインコンテンツにスキップ
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108回答 すべてを表示
Why do I have these lines?
Samsung Galaxy Tab A 10.1 Model SM-T580 (WIFI)
Out of nowhere I have grey, white lines going across my screen. And I can see impressions behind it of software I was previously using. If my software application had background color, it is still there. If not, the background is white with grey lines thru it. Haven't dropped it, no water on it. Nothing placed on top of it. It's working. Just very distracting. Can anyone explain to a non techie person what I should do? Is having it repaired possible or must it be replaced?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @sisree ,
Try starting the tablet in safe mode and check if the lines are still there.
If they are not there when in safe mode then a downloaded app is the cause of the problem. The trick is to find out which one. You need to uninstall each downloaded app one by one and test the tablet in normal mode between each uninstall. When it tests OK the last downloaded app that was uninstalled is the culprit.
If they are still there when in safe mode, check if a factory restore resolves the problem.
Before you perform a factory restore, backup the tablet using the tablet’s backup feature.
Be aware that a factory restore will erase all your data and downloaded apps. It will restore the tablet to its’ factory default condition. That is why it is important to backup the tablet first.
Once the backup has been competed, factory restore the tablet using the tablet’s factory restore feature.
Once the tablet has been reset to its’ factory default condition, check if the problem is still there or not.
If the problem is still there then you have a hardware problem.
If it is now OK, restore the tablet from the backup that you made earlier, using the tablet’s restore feature.
Once it has been restored to what it was before you started, check that it is still OK. If it is then the reset has resolved the problem
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
RMW さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 34
今までの合計 2,661
