How to replace the sd card cover on nikon d3200 camera
The exterior door/cover for the SD card slot broke. I can obtain a replacement door, but do not know how to replace it. Any resources?
Not sure how close the screws will be to that panel, might want to look at the replacement part for where it has screw holes!
I took that part off while doing other work, on my D500, and although it showed 2 screws, there were 4 more hiding under 2 pieces of rubber! May need to peel the rubber up around the door to find them.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 532
