メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
Magnavox VCR /DVD recorder combo , VCR turns off after 5-10 seconds
I have a Magnavox VCR/DVD-Recorder combo , I just purchased in order to transfer old VHS tapes to DVD. I just realized the VCR shuts off completely after about 5-10 seconds . It doesn`t just stop the tape, it turns off the unit. I tried the DVD and that one works without any problems . Can anybody tell me what the problem is and how to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Our similar machine won't stay on longer than 5 seconds and shuts down before we even have time to put in a tape. We finally did get a tape in but it shut down right away. These are not 'copyrighted' tapes. Anyone got any solutions?
さんによる
When the VCRs sit for a while the belts can cease up. If you open them up and work the gears manually they will often regrease themselves and the VCR will start working again.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Good day, the devices in question may be older model VCR’s. The issue is the drive belts are old and stretched out or broken. The only way to get this device to work again is replace all drive belts and give the gear a good dose of grease. I had this issue with an older Realistic VCR Model 19. I am going to find parts and attempt a repair. So, you may have to locate a repair shop in your area which may be difficult because the repair shops are scarce.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I have the same problem and cleaning the little infrared thing solved that but now an idler(correct name?) won’t go back far enough to grab the ribbon
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You are copying something that has a copyright protection. It will shut down when it receives a copyright signal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When the VCRs sit for a while the belts can cease up because the grease freezes. If you open them up and work the gears manually they will often regrease themselves and the VCR will start working again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Regina Roberts さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 151
今までの合計 5,648
