Phone not charging after screen repair
Any ideas why phone is not charging after screen assembly replacment. Its stuck on 1 percent battery life???
I think you have damaged a chip on the board or not seated the battery connector properly.
このアンサーは役に立ちましたか?
:(.. i hope its not the chip. Bit if it is any possibility of getting a possible logic board replacement, i will disconnect and have a look and reconnect it again...
thank you chris
Chris thing is phone switches on when i plug in the charger but its stuck on 1 percent??? Any ideas
no need for a replacement, a good repair shop that does microsoldering can repair for you
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 148
Tracey Homeward さんによる
Help..the chip was replaced but i am being to that the phone still wont charge..does this mean the phone is ruined?
A reputable shop who repaired it should have checked that it charged after repair. What did they say?
This should be repairable.
chris さんによる
they said the component is still in place but slightly damaged and cannot be fixed.. i dont accept that, what do u think?
