メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
467回答 すべてを表示
Won’t start up
Hi can anyone advise please?
my iMac won’t start up. I have mains power to the psu and the following DC output voltages on pins 1 to 16 But nothing else picture sounds etc it’s completely dead.
psu board ref ADP-310 AF B 614-0476 China
Pin 1 earth
pin 2 2.7mv & 1.2v when output plug disconnected
pin 3 earth
pin 4 11.92v
pin 5 earth
pin 6 1.1mv & 3.6 v when output plug disconnected
pin 7 earth
pin 8 earth
pin 9 earth
pin 10 2.8mv & 1v when output plug disconnected
pin 11 11.92v
pin 12 11.92v
pin 13 11.92v
pin 14 11.92v
pin 15 11.92v
pin 16 earth
ps. Pins 2,6,10 dc voltages increase when DC output plug disconnected
both large capacitors 300 v dc
Does anybody have the wiring diagram or details of the actual figures for testing my psu before I purchase a new?
Looking forward to some replies ;)
thanks for your time
paul Williams
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi I just received my new power supply unit and I’m gutted I still only have 1 light on my board while viewing in the dark from the lower vents ;(
regards
paul
さんによる
コメントを追加
2件の回答
ベストアンサー
Paul
I,ll save you the trouble. See Diagram below. The are four diagnostic LED’s located on the logic board. The LED meanings are as follows, but if LED #1 and LED #2 are on then the power supply is OK. You can only see the LED’s through the vent holes to the left of the memory modules on the bottom of the iMac. I had to make the room completely dark to be sure if they were on or not. All of mine were off and I tested that there was power coming out of the cable and into the imac with a multi meter
LED Functions
LED #1
• Indicates that the trickle voltage from the power supply has been detected by the main
logic board. This LED will remain ON whenever the iMac is connected to a working AC
power source. The LED will remain on even when the computer has been shut down or
put to sleep. The LED will turn off only if the AC power source is disconnected or the power
supply is faulty.
LED #2
• Indicates that the main logic board has detected proper power from the power supply
when the computer is turned on and that logic board voltage regulators are functioning
properly. This LED will be ON when the computer is turned on and the power supply is
working correctly.
LED #3
• Indicates that the computer and the video card are communicating. This LED will be ON
when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON
and you heard the startup sound, but LED 3 is OFF, then the video card might be installed
incorrectly or need replacement.
LED #4
• Indicates that the computer and the LCD panel are communicating. This LED will be ON
when the computer is turned on and video signal is being generated. If the LED is ON and
there is no image on the display, then the LCD panel, the LED backlight board, or the cables
between might be installed incorrectly or need replacement.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi, many thanks for taking the time to send me all this information. I did notice recently during complete darkness that I only have 1 Led on while looking through the bottom vent ;( so that would confirm then that my PSU is not working;) that’s amazing
さんによる
Hi there, new psu fitted and still only 1 led light on and it doesn’t fire up ;( any recommendations? Thanks
さんによる
コメントを追加
Paul what number LED is on. ? You mentioned that you have one LED light on which indicated the PSU is faulty. I don't think that is the case because the description for LED 1 ends with “. The LED will turn off only if the AC power source is disconnected or the powersupply is faulty.” which to me infers that the only time the power supply can be considered faulty is when ALL the LED lights are off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Paul williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,189
