メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
420回答 すべてを表示
Dead after 6 months... Culprit is I/O Board Cable?
I’ve had this 2017 13 inch macbook air for six months, and now its dead... sort of. One day after it stopped turning on I went through the usual procedure. SMC reset did work according to the magsafe light but the laptop still wouldn’t boot. After trying lots of things inside the machine, I found that if I unplugged the battery and the cable that runs from the top of the I/O Board to the MLB, the machine would boot just fine. I would plug the cable and the battery back in as soon as the fan started spinning. It worked fine for a week or so, then the same thing occurred. Did the same fix and the machine worked for another week. There has been no damage whatsoever to this machine. Any ideas why this is happening?
UPDATE
Screenshots from Coconut Battery here.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
I would start off checking the battery to see how the charging logic is doing. Install CoconutBattery. Take a snapshot with the MagSafe charger connected and a second one disconnected. Paste both here for us to see iFixitでの質問に画像を追加する方法
さんによる
Just added screenshots.
さんによる
mmm ... I see zero watts in both. Lets run the battery down a bit ~15 % and test again.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I’m suspecting the I/O board is the issue. The MagSafe connector cable to the main logic board is likely damaged. MacBook Air 13インチ Early 2015 I/Oボードの交換.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Have tried three known good I/O boards and cables already on this unit. Same issue persists.
さんによる
コメントを追加
回答を追加する
William Emanuel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 107
