Can I add a SSD and keep the current hard drive?
I want to have 2 storage devices, in other words.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here’s the guide for installing an SSD 2.5” drive.
Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit
You can then use the optical bay for an additional standard drive.
@danj shows how to do that here:
このアンサーは役に立ちましたか?
Hi David
Technically it is possible, one way is to sacrifice your optical drive and get a optical drive to sata bracket converter to fit your sata drive.
このアンサーは役に立ちましたか?
Do keep in mind the optical drives SATA port is slower! SATA II (3.0 Gb/s) Vs SATA III (6.0 Gb/s)
Using the dual drive kit is better.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 51
