メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3477回答 すべてを表示
Maytag washing machine won't run high spin cycle
Maytag front load washing machine model YMHWE251YL00
It will not go into the high speed spin at the end of washing leaving the cloths still very wet.
The drum will agitate to wash and will do a low spin but when it should go into high speed spin the drum stops, the pump still runs but nothing else is happening. It has 4(?) different spin speed options and none of them work.
All the wash cycles work, the drum does turn, pump works, hoses are not kinked, drain filter is clean just won’t spin.
I am leaning toward the control board but am wondering if there is anything else I should look at before ordering a $110 part.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Not great on washing machines but this does not sound like the control board to me. I would do a little more research. There is a chance I am wrong but with other features working and the spin being part of the same cycle it would seem there is something stopping the spin….. just guessing could be a power issue or a loose connection from the control board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SaskClay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 1,311
