No heat but power on my toaster oven?
My Black and Decker convection oven has power( red light on) but no heat (heating bulbs don’t work)
Hi Lynn,
Has this just randomnly occured or was it during use? It could be that the bulb(s) may have blown as this is a typical thing to happen to toaster ovens through all of the heat cycles they experience they can wear out rather quickly. I would suggest an over heat protection feature although you stated the red light is on meaning this is not the case. Do you have the model number and I can take a closer look at a possible solution for you.
このアンサーは役に立ちましたか?
I have the same problem with my Elite toaster oven, model #ERO-2008S
過去 24時間: 3
過去 7 日: 9
過去 30 日: 45
今までの合計 1,712
