How to repair the flash latch not locking
he flash latch need to be fixed, as it does not stay down
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I believe that this is caused by a little plastic hook that holds the in-built flash is broken. If you do a Google search, you will find that this is a very common error. There is an interesting write up about the repair of one of those on a D90 which is essentially the same flash unit. Just in case you do not have it here is the service manual for that camera. Good Luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,639
