メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
MacBook fan in constantly running loud, battery not showing
Hi everyone,
I’m stuck with a macbook unibody late 2008 with a huge problem.. The fan is constantly running loud from the moment i power it up, the magsafe light is dim green, the battery don’t show at all.. each time i have to (unplug the magsafe hold the power button for 5 seconds plug the magsafe while holding for an other 5 seconds release the power button and power up) in order to power up my mac, and it shuts down every time i unplug the magsafe… help please?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It sounds like you have a couple of different problems!
The first is your battery & the charging logic is likely in bad shape. Lets run this app so we can see things more clearly CoconutBattery Lets get a snapshot of the main window with the MagSafe connected. Post it here for us to see iFixitでの質問に画像を追加する方法
The racing fan is the SMC trying to manage an overheating condition, at least thats what SMC thinks. This could be caused by liquid damage or a failed sensor. To investigate this weill need to us a different App TG Pro is what I would use as it allows us to see things more clearly. Again, take a snapshot of the main window showing all of the sensors (you may need to grow the window) and past it here for us to see.
Lastly, physical inspection to see if any corrosion or dust build up needs to be cleaned up. Get a small soft pain brush and a can of can’ed air so you can scrub down the dusty parts and us the can’ed air to blow the debris off. Given the systems age you should clean off the old thermal paste and apply fresh paste. So here’s the guide to fully remove the logic board to inspect it (both sides) MacBook Unibody Model A1278 Logic Board Replacement and here’s the info on the thermal paste 放熱グリスの塗布方法
Electronics Skillsの画像
ガイド
放熱グリスの塗布方法
難易度:
中レベル
5 - 20 minutes
MacBook Unibody Model A1278 Logic Boardの画像
ガイド
難易度:
難しい
2 - 4 hours
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hechem Mihoubi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 650
