メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
統合ディスプレイを持たない一般的な据え付けのコンピューターです。
1202の回答 すべてを表示
Can I take my hard drive from my old pc and put it in my new pc?
Hello,
I am upgrading to a better computer and I was wanting to know if I could take the hard drive from my old pc(hp) and put it in the new pc(dell). The problem is, the HP has an AMD cpu, whereas the dell has an intel cpu.
The hard drive itself is a decent one, it is a Western Digital blue 1TB WD10EZEX, fast little drive.
The only problems I could see happening are driver issues, but I have driver install/repair software that works well.
So my question is, will this work or not?
**Note, this will not be permanant, I only plan to run this setup untill I have enough money to buy a new HDD and SSD.**
Update 1/27/19
I just tried this today, and it did not work!!. The computer turned on and everything, but there was no display and it seems to have failed to detect the wifi module because it would not come online on teamviewer, so I wasnt able to go in and remotely fix the problem.
What do I do now?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You should have no problems as long as the old drive a an SATA rather than an IDE. In other words, if the connectors are the same you are OK.
この回答は役に立ちましたか?
スコア 1
コメント:
So there shouldn't be any issue with switching to an entirely different processor? Also, both pcs use sata connectors.
さんによる
I just posted an update, more or less it did not work at all.
さんによる
Programs like Acronis True Image have their universal mode which automatically updates drivers during first boot up on a "new" system.
I've successfully used it many times.
さんによる
コメントを追加
回答を追加する
Connor さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 56
