メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
I'm scared to turn on my iPhone
I dropped my phone in my bathtub earlier and I got scared. I opened it up and used the cool setting on my hairdryer to dry the phone and its hardware and everything. I put it all back together and Now the screen wont go all the way in and I’m scared That i’ve accidentally punctured my battery. Its all in place but I’m scared to turn my phone on. Should I turn it on or not? what would you recommend?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hello,
I am understand that your feeling so don’t be panic just clean your phone internally means If your handset has a resemble battery, similarly your phone has some kind of port cover or even a removal back panel, open it up to let your handset air out,
Don not dry your phone with a blow drier because the heat from the drier could damage your handset internally components permanently.
After the clean out your device cleaner (liquid) after that on the phone and check it. But you will be this work quickly,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Vidhi,
I can totally sympathize with you here - a punctured lithium ion battery is no joke but signs of swelling are pretty easy to spot
Seating the display bezel in the phone body does require a bit of extra force for it to click into place and for the display to be seated correctly.
Once you’ve given the battery another inspection, try turning the phone on. If the battery is expanding, you’ll be able to see the pressure marks plainly on the LCD. You need to turn the phone on to assess what other damage may have occurred and determine if you are able to repair it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vidhi Patel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 59
