My laptop won't turn on
My asus vivobook suffered from.a tea spill 3 months ago I opened up the back dryer out and it still won't turn on maybe power switch is broken please help
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Has it been working since the spill? Simply drying out the tea probably won’t have been sufficient - you need to clean it up with isopropyl alcohol.
Assuming the tea went in through the keyboard, you’ll probably have to remove the motherboard in order to clean its top surface. The tea probably won’t have done the keyboard any favours either.
このアンサーは役に立ちましたか?
So it never turned back on once the tea spilled on it . And I took out the motherboard yesterday and wiped it down with rubbing alcohol. What next
Also there was no evidence of corrosion on the motherboard
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 171
