How do I install my back glass properly?
Hello,
Everytime I try to install the top black glass for the iphone se, it either breaks from pressure or sticks up and isn’t secure. Is there anyway to fix this?
この質問は役に立ちましたか?
Hello,
この質問は役に立ちましたか?
Glass should come with an already cut biadhesive and you would just need to moderately heat it up and apply little pressure to stick it properly in place unless there’s something out of place. Make sure with a good light source and a magnifier there are no old shards left in place. Housing replacements are likely never original parts and the glass may be thicker than needed..check with the original broken parts if you still have them around that thickness is the same.
このアンサーは役に立ちましたか?
Thanks, I'll try heating it up this time and see if it works
Check your model again.
Apple iPhone SE Back Cover
このアンサーは役に立ちましたか?
He has the right model, just realized he means the black parts at the top and bottom of the back of the phone
Hi OneSteelTank,
I have recently encountered this problem. The way I got around this, was by making sure that the back frame is sitting flush around the whole of the phone. If all parts of the frame a sitting flush, then check your camera/flash assembly as this is the problem that I had. My rear camera was sitting 1mm to the left, therefore, whenever I pressed down to adhere the glue, my glass panel cracked upon the pressure.
Upon this not working, a complete tear-down may be the best solution.
Kind regards,
Kyle
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 157
2 件のコメント
Hi i'm just confused, are you sure you have an SE? they don't have a back glass
Tommy Gurreri さんによる
Yes I'm sure, it has 2 slabs of glass - one on the top and the bottom. Just like the 5/5s
OneSteelTank さんによる
