I think I have a crack in the reservoir before it connects to the pump
I believe I have a crack in the reservoir where the water flows into after coming from the tank? Any idea how to further diagnose and if so how to replace it?
Update (01/23/2019)
If you look at the top of the resivoir there's a water droplet that builds up. It seems to leak from the top of this section. I would dispense normal water out just to clear the tubes, but it won't pump out and I observe a leakge at this location @jayeff
この質問は役に立ちましたか?
8 件のコメント
Hi @wiliam94 ,
What is the model number?
jayeff さんによる
I'm not sure of the model number since I bought it off of someone. However it's the one with the touch screen and says Keurig 2.0 on the button.
William さんによる
@jayeff I have placed photos in the post.
William さんによる
Hi @wiliam94 ,
Not sure re your device but are you sure that it is a crack and that there is not just a good seal where the reservoir sits on?
To me it looks like there is an o ring on the inlet/outlet? where the hoses are connected to. If there is perhaps it need to be replaced.
jayeff さんによる
Check the picture I added above @jayeff
It seems as there's a water droplet that rests at the top, and when I dispense water from the machine it doesn't drip at all and water leaks at this point
William さんによる
3件以上のコメントを表示
