Fuse for cigar and console
Where is the correct fuse for cigar and middle console power outlet
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
I don’t know your vehicle but according to the owner manual for a 2000 Ford Mustang (you don’t state the year model) the fuse for the cigar is fuse #1 in the passenger compartment fuse panel. The fuse panel is located below and to the left of the steering wheel by the brake pedal.
The manual also shows that fuse #9 in the engine bay power distribution box is labelled as Auxiliary Power Point which may be worth checking out to see if this is the one for the console power outlet.
Here are some images taken from the manual to show the fuse locations and designation.
cigar fuse
auxiliary power fuse
(click on images to enlarge for better viewing).
Hopefully this is of some help.
このアンサーは役に立ちましたか?
2003 centennial edition 100 badges on mustang gt
@Joe A
For a 2003 Ford Mustang it should be the same fuses as shown above
過去 24時間: 5
過去 7 日: 23
過去 30 日: 121
今までの合計 5,238
