メインコンテンツにスキップ
The sedan version of the compact Toyota known as the Echo, Yaris, or Platz depending on the market. The hatchback version of the Echo/Yaris is known as the Toyota Vitz.
11回答 すべてを表示
My car can not display the engine light even when there's a problem
I bought this 2004 Platz with a replaced 1sz engine. (I don't know why the engine was replaced). I have been having trouble with it over sluggish acceleration, shaking and even stalling at stop lights. Even now the issue is worse because the car can not accelerated however much I press the gas pedal. I had it diagnosed for faulty oxygen sensor, faulty mass airflow sensor and faulty throttle position sensor.
Am concerned that with all these faults the ECU does not display the check engine light to warn me in advance. However when I turn the ignition key to ‘acc' the light is there.
Could it be a problem with the computer or the new engine is not synchronized with the computer. Someone help me please because the diagnosis guy couldn't figure it out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hello.
I had a very similar problem in a toyota Echo 2004 (in Europe Yaris).
in my case the engine trouble light did not indicate the problem because I had exchanged components of the brand with compatible components.
the ECU would never tell me the error because it would have been 'cleaned' by the 'mechanic' who traded the components of the brand for compatable components.
the solution was to replace the compatible components (BOSH) with parts of the DENSO brand returning to the original
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dominic nyangena さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 31
今までの合計 351
