メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Replaced Hard Drive Cable & Hard Drive to SSHD - MacBook Pro is slower
I replaced my hard drive cable a few months ago and then recently cloned my hard drive onto a SSHD and then installed it into my MacBook, but it made it slower and apps keep freezing/crashing after the upgrade.
  • I purchased both the hard drive cable & the 1 TB SSHD Hybrid 2.5” drive from iFixit
  • I’m running macOS High Sierra 10.13.6
  • I have set the SSHD as my default startup disk
I saw in some forums that suggested it may be an issue with the hard drive cable. But what if I just replaced it?
IFIXIT only offers 1 kind of hard drive cable for my device. What other things can I try in order for my SSHD to work internally in my MacBook?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
It may be a problem created by Apple. Because it may have tried to impose APFS formatting with the High Sierra on your SSHD. I’ve see this before. Make a Time Machine backup. Reformat your drive GUID, Install High Sierra or Mojave. Now use Migration assistant to move your Apps and data. This should solve your problems.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Eva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 90
