メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
279回答 すべてを表示
How to repair iPhone XS Max camera glass
Does anyone know how to repair the camera glass of the iphone xs max?
i can only find the glass with the ring on ebay but the ring for the glass is soldered on the frame of the phone. i tried to heat it up but i cannot remove it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
最も参考になった回答
Sorry guy you’ll need a new case unit and transfer all of your phones guts to it. As you can see here in the iPhoneX teardown on Step 22 iPhone Xの分解 the back glass is well glued and the lens cover glass frame is welded to the case! This is the same for the Xs Max.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Just replace the back cover...they sell it on this site actually.
iPhone XS Max Aftermarket Blank Rear Glass Panel with Lens Cover
iPhone XS Max Aftermarket Blank Rear Glass Panel with Lens Coverの画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 1
コメント:
Still a bit of work to get the old glass off.
さんによる
Oh, I'm sure it is... iPhone's are CRAZY to take apart and crazier to put back together ( IF you get them apart successfully lol)
さんによる
コメントを追加
The fastest and by far the simplest and most effective way to replace the back camera glass on an iPhone XS Max is to replace only the lens. This can be done for around $5-$6. First, you heat up the lens, carefully remove it, and make sure all of the excess glass is removed. After that, you should be able to grab the replacement lens (linked below), add a little bit of adhesive and put it on. I have used this method before on an iPhone 7 Plus and it worked perfectly! Just make sure that when you are removing the glass you are super careful not to touch the camera sensor with the glass, fingers, or even tweezers. Hopefully, this helped you!
Replacement iPhone XS Camera Glass: https://www.ebay.com/itm/OEM-Back-Camera...
Replacement Video: https://www.youtube.com/watch?v=sMXesLDC...
このアンサーは役に立ちましたか?
スコア 0
コメント:
The replacement camera glass has ring on it. The video didn't show how to remove the whole set with the ring. Do you have another video related to the camera glass on eBay?
さんによる
Sorry for the late reply, here is a link to the correct replacement glass that should be used when doing a glass only repair. Thanks for catching that I should have double-checked before posting. Hope this helps!
Replacement iPhone XS Camera Glass: https://rb.gy/nxwlrn
P.S. I had to use a URL shortener for this ebay link because it ended up being more characters than i am able to comment (1398 of 1024).
さんによる
コメントを追加
https://youtu.be/5q8OzxyHKC
hope it helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if I were you id heat it up and remove the glass from your new piece and put that on with a little glue, you can remove the whole thing by breaking its broacket from the inside but you risk breaking the back glass (presuming they are like iPhone 8)
このアンサーは役に立ちましたか?
スコア -1
コメント:
When you do that you break the flash bulb. I’ve seen several YouTube videos that say to do this, but when you do you won’t have a rear flash/flashlight on your iPhone any longer.
さんによる
@tjburke The only way that you would "break the flash bulb" is if you put too much direct heat onto the flash unit, too much heat in general, or you decided to poke it and physically destroy the blub. Otherwise, I have successfully completed this replacement on an iPhone 7 Plus and everything was fully functional afterward. Please do not spread disinformation around about something if you have not tried to do the repair.
さんによる
コメントを追加
回答を追加する
pacuna GmbH さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 132
今までの合計 22,709
