メインコンテンツにスキップ
Released October 2014, rectangular mobile speaker with Bowers & Wilkins on the front and back.
2回答 すべてを表示
Why is my T7 stuck in service mode?
Recently while trying to remedy what I thought was a pairing issue i used the Bowers & Wilkins Bluetooth Utility\1.2.2\Bowers & Wilkins Bluetooth Utility.exe". I thought I was doing the right thing and used the utility to clear the paired list. Now my T7 is stuck in what i’m told is “Service Mode” and i cannot release it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It's a really simple fix:
  1. Plug the speaker into your pc using the micro usb (labelled service) port on the back of the speaker
  2. On the Bowers and Wilkins firmware update software (free to download from the bowers and wilkins website)
  3. If the speaker shows up on the software, click 'eject speaker' on the bottom left, this sets it back to the default mode and it should work perfectly from this point.
  4. If the speaker didn't show up on the software, try unplugging it and plugging it back in. Note that the speaker must be turned on in order to be detected. If this still doesn't work, try restarting your pc and trying again. Otherwise contact Bowers and Wilkins support.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Duckworth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 582
