メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2687回答 すべてを表示
Can’t answer incoming calls
Have a weird one have an iPhone 6s works great but when a call comes in screen stops working can’t answer and phone will continue to ring until I do a hard reset. I have taken it apart and cleaned it no water damage have replaced the screen install a new battery.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Fix for iPhone keeps ringing but screen freezes: I know this is an old thread, but maybe it will help someone else. This happened on my Mom‘s iPhone 6. It started after I enabled Announce Calls for “Always” for her (under Settings/Phone). I turned off Announce Calls and the problem was fixed. The feature works on my iPhone 8 so it also could be a software update issue.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
The person that post about the announcing calls. Thank you soooo much my phone as driven me crazy but you helped fix it. I had tried everything. I turned off the announce calls and the phone is working again.
さんによる
Tried this, no luck. Yikes!
さんによる
I tried this, and it worked!!!!
Before the I phone 6 was ringing and I could not answer calls and front screen would freeze. only way out of it was turning phone off then on again .
Also on outgoing calls I could only call out once before locking. would have to turn phone off then on again.
Text messaging worked the whole time
さんによる
コメントを追加
I would check and make sure there is not a software update that is missing. Sounds like a software issue. Go to setting ->General->Software Update and See if it shows and update that is needed. Best of luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Patrick Dean Willard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 4,831
