メインコンテンツにスキップ
Moto E4はMotorola Moto E 第4世とも言われ、モデル番号は XT1765、XT1766、XT1767、XT1768です。2017年6月に発売されました。
14回答 すべてを表示
Can't send text messages until reboot.
Occasionally, my phone will refuse to send text messages until reboot. Calling is still functional. This usually happens with an uptime of >24 hours. I have tried using different messaging programs, disabling and re-enabling mobile data, and cleaning the sim card contacts. What could be causing this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Hi @ian_ ,
Are you talking about SMS or MMS?
SMS doesn't require mobile data to be enabled, MMS does.
Have you tried using the phone in safe mode to see if it works OK?
If it does then a downloaded app may be the cause of the problem.
Just a thought.
さんによる
I have only tested this issue with SMS. I have not tried using safe mode due to how unreliable the replication of this issue is, but it's existed pretty much since I got the phone. I can try putting it in safe mode for a couple days to see what happens.
さんによる
コメントを追加
1 件の回答
I agree with jayeff, I believe its a APN issue. You can google the APN Setting of your carrier and input that into your settings to allow your phone to send certain messages.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have tried resetting my phone to default APN settings before, I should have mentioned that in the question. I did look into changing the APN values to something else, but when I try to edit them, every option besides "APN" itself is greyed out.
さんによる
コメントを追加
回答を追加する
Ian さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 10
今までの合計 157
