メインコンテンツにスキップ
My Bosch nexxt dryer won't tumble. The lights come on but no tumble
My Bosch nexxt dryer won't tumble. The lights come on and it beeps as if the cycle is about to begin however nothing happens. I've hit the reset button on the right side the little red one and also hit the reset button on the left by the motor and nothing. The belt is intact and no obstruction. I'm lost... Any suggestions
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Cause 2
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you much appreciated I will certainly try these things and let you know how it goes!
さんによる
I have the same problem with the dryer not starting up. The thermofuse reset will not depress and the continuity is good. Continuity/resistance/ isolation is all good on the heating element, too. When you press start the dryer sounds normal and the door latch clicks, but nothing after that.
さんによる
コメントを追加
回答を追加する
Mari さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 64
今までの合計 6,425
