My fitbit Versa is not charging
My fitbit Versa is not turning on and when I try to charge it, it does not charge or start. Is it a charger issue or a battery issue?
It could be either, it’s hard to say for certain. Was it working fine previously? If so, the battery seems to be fine unless it was left out for ages, depleting the battery to the point where you have to charge it for a while for anything to happen. It could also just be the charger as if it is not going on charge or recognising that it should be charging then that may be your issue. I would say the charger is more likely and one to start with but if still nothing, then definitely battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,380
