Can I get rid of a scratch on my screen?
I got my Evo a few days ago and got a scratch on my screen, is there any product or method i can use to get rid of it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
glass cant be polished as you would any other hard surface. i have heard some products that could be applied in the scratch and that product is then polished to make it look smooth and dissapear... what it does is fill the gap.... but actually removing enough material of the glass to make that scratch indentation is unlikely.
このアンサーは役に立ちましたか?
I've owned an HTC Evo 4G for years and have successfully removed screen scratches from it as well as my iPod using the glass compound from the company below and a glass polishing cloth.
It usually takes me between 10-15 minutes by means of hand buffing, and probably less with a dremel tool of some sort at a lower speed. Careful with power tools though, do NOT burn the screen; it can happen easily. I have found hand buffing to be a safer method and there is enough compound to repair multiple devices such as iPhones, iPods, Android devices, etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,264
