メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
610回答 すべてを表示
Why does my new logic board only accept OS X Yosemite?
My hard drive uses the MacOS Journaled format.
I put in a new logic board and every time I try to install High Sierra from a USB key , the installation goes as planned until it reboots.
The problem is that the computer keeps rebooting indefinitely after a minute or so.
I used internet recovery and it downloaded Yosemite (!).
I guess it’s a matter of firmware, isn’t it?
But it seems the only way to update the firmware is to install High Sierra, which the logic board doesn’t let me do.
Is there a way I can solve this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Depending on what you had on your system before as well as how you enabled OS recovery you will get the original OS the system had. Pressing Option & and the R keys will get you the highest your system will support
Review this T/N Mac startup key combinations and this T/N How to reinstall macOS from macOS Recovery
このアンサーは役に立ちましたか?
スコア 1
コメント:
Hi there, thanks for your response. I tried the Option+Command+R but since Sierra was never installed on it, this command doesn't behave the same way.
I still can't boot up, even under Yosemite. It keeps rebooting after a few seconds.
Could it be because there is no battery connected to the logic board?
Or maybe I didn't connect some cable correctly to the logic board?
さんによる
Yes, you need to have all the pieces installed and a working battery ;-}
さんによる
@danj If the High Sierra install put the APFS format on it, it may not accept a lower system.
さんによる
コメントを追加
回答を追加する
Alex222 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
