メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
The Golf Mk5 was introduced in Europe in the autumn of 2003, reaching the UK market in early 2004. In North America, Volkswagen brought back the Rabbit nameplate when it introduced the vehicle in 2006.
14の回答 すべてを表示
Battery Boiling over problems
Just had Factory alternator installed a few months back. It fixed some starting issues. Not now I noticed some acid leaks on the driveway and have this corrosion issue in the battery box
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Test the voltage of the battery . With the car off it should be 12.5 to 12.8 if its higher the battery is overcharged . With the motor running the voltage should be slightly hire 13.7to 14.7 volts if its running higher were looking at an over charge condition . This is caused by a faulty voltage regulator . Not all cars have a voltage regulator in the alt some are external to the alt. Finally the issue could be a bad battery check the posts and see if either is loose . If you can move the post replace the battery. If the battery smells of acid you should replace the battery. If the sides or bottom are swollen or leaking replace the battery . if the battery is fine then you can clean the corrosion with water and baking soda . once clean cover the post and terminal with grease to prevent further corrosion . Hope this helps
この回答は役に立ちましたか?
スコア 5
コメント:
if it is chargeing 14.7 it is way to high
さんによる
コメントを追加
回答を追加する
Audreys Gulf さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 1,017
