メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s doesn't recognize SIM Card
Hi there everyone,
I recently bought an iphone 5s which doesn’t recognize any SIM Card put into it. The strange thing about it is that the iPhone doesn’t ask for the SIM Card in the first place. My usual experience with iPhones is that, if you dont have a SIM card inside, there will be a notification telling you that. This time around there’s nothing, which is why I wonder if my problem is possibly slightly different to the normal SIM Card not working one. Maybe its a software error?
Thanks,
Minas
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
There is a “switch” built into the SIM card reader to detect the presence of a card. Normally, the phone should notify you if a SIM card is not present, as you suspect. So the fact that you are not being notified leads me to suspect an issue with the SIM card reader. You could open up the phone and take a closer look at the reader to see if there is any internal damage. The reader can be replaced but it requires a micro-soldering repair.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Hi and thanks for the help! Could you clarify what the "switch" exactly is? Is it a physical switch that I can toggle? I'd rather not open up the iphone, but will if I have to.
さんによる
Inside the SIM reader, an inserted SIM card forces a disconnect between two metal contacts.
さんによる
コメントを追加
回答を追加する
Minas Mayth さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 877
