メインコンテンツにスキップ
Repair guides and support information for televisions manufactured by RCA.
166回答 すべてを表示
Won't turn on anyway to reset it?
My RCA 32 inch. Won't turn on anyway to reset it? I tried to reset it the remote but there was no clear button on the remote so I could not use the remote to reset it. There is a red light on but everytime I try to press the power button it doesn't turn off and I don't know what to do.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
tv cut on an off red light flashing I can unplug it an it flashes one time than red light flashing
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Katelin Hieber  it is possible that this is a power board issue or a main board issue. We would need you to give us the complete model number for your TV and have you remove the back from it. Take a look at the boards (after unplugging the set) and check for obvious damage like domed, leaky capacitors etc. After that you will need a multimeter to check the fuses, connectors etc. You can always post some pictures of your boards with your question so that we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Me too. I'm sending pics of back. Fingers crossed hoping you can help
さんによる
コメントを追加
回答を追加する
Katelin Hieber さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 8,669
