How to know IMEI in iPhone 4? Written on the parts?
Hi,
Except from the Settings>General>about, And from the Sim card tray - Is there anywhere else where i can see the iPhone's 4 IMEI?
Thanks
この質問は役に立ちましたか?
Hi,
Thanks
この質問は役に立ちましたか?
You should be able to look up the IMEI by entering in *#06# on the keypad. It works on my 3GS anyway. Just tested and it works on the iPhone 4 also.
このアンサーは役に立ちましたか?
I know that :-)
But what if the iPhone could nod turn on?
Is it written somewhere on the parts itselves?
Not as far as I know.
I found a extended guide & ways to get iPhone's IMEI code, read the methods here to Find iPhone IMEI Number
このアンサーは役に立ちましたか?
Thank you, the easiest way is to remove the sim tray.
There is a small size programme of less than 2Mb called 'Tinyumbrella'. Download it and run, it has a row for IMEI and it will show you. Besides it saves your SHSH just in case you have installed a newer version of Apple's IOS and you want to go back to the previous version, and the most interesting thing about it is that it does not install anything on your system.
Just go to tinyumbrella.com and download it. I hope this helps!
このアンサーは役に立ちましたか?
tinyumbrella.com does not work. It is simply a picture of a European Mopad... wtf
@Kia Love, ,ay be because this question is over a year old. If you need to download tinyumbrella, use this link. BTW I'd appreciate if you DBD and delete your wtf.
The IMEI number (as well as the serial number) of the iPhone 4 is written on the sim card tray. Eject the sim card tray and look on it. You will find the numbers.
このアンサーは役に立ちましたか?
I wrote in my question, if there is any other place except the sim card tray..
Thanks
If your Iphone is lost or stolen and you still have the IMEI code these guys should be able to help you track your Iphone with IMEI:
https://www.facebook.com/Iphonetrace and their main website http://www.iphonetrace.com/
このアンサーは役に立ちましたか?
There were times I lost the phone, sometimes my phone is stolen, once I managed to find the IMEI on the phone using the service: Find stolen or lost phone by IMEI or Number
このアンサーは役に立ちましたか?
Can you locate your iPhone by its IMEI? I came across this page http://www.iphoneorten.de/verlorenes-iph... and the author say that it is possibly. has anyone used such apps?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 26,722
7 件のコメント
Shai it helps if you Update your question instead of editing it. It is difficult to keep track of it if you edit it, after somebody gives an answer.
oldturkey03 さんによる
take a look at this guide...iPhone4のディスプレイアセンブリの交換 step 24.. there is a serial no. or barcode on the inside of the metal frame..is this an imei no??? might be worth a look.
pollytintop さんによる
Thanks... But I have no idea what is this bar code :\
Shai さんによる
What more do you want? Not by turning it on, not by looking at the sim card tray? You want to shake it and say the magic word and it'll write it in dust on the screen?
rab777hp さんによる
on the box it came with??? just in case you have it...
Rab you made me laugh...quite a lot. thanks!
pollytintop さんによる
2件以上のコメントを表示
