メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
I have hard drive problems, how to test drive to board cable
As title says hard drive problems, disc utility can't repair. I put it in an external dock and booted from install dvd and disc utility says all is well. This drive was brand new a month ago. I ran disc repair and am now in the process of installing os 10.6. If it installs, and it looks like it will, how do I test the hard drive cable and plug?
Thanks Walt
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
The only way to test the hdd cable is to replace it with a known good one and see if there is a difference.
Even a little shock can damage a spinning drive
you could try to erase the hdd and reinstall the os
You can find a hdd cable on eBay
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I did get the OS installed on the same hdd, so that's definitely not the problem. I used a usb hd dock and booted from the install dvd. It boots and works from external dock.
さんによる
Although it loaded, it now has the dreaded beachball. It freezes with the least provacation. I opened activity monitor and it showed hardly any cpu activity, like a .6 for system. If I click anywhere else it freezes and I need to force shutdown. There is no hard drive internally so I'm guessing it is just too much for it through usb. I'm 99% sure the root cause is the drive cable so I'll do that as soon as I can. Hopefully that cures its ills lol.
さんによる
コメントを追加
回答を追加する
Walter Lawler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 65
