Changing iPhone7’s logic board
Hello. If I change the iPhone7 logic board, will the new one be locked on certain networks or even locked by the iCloud as in wiping iPhone?. I want to buy an open one. Thank you
The new logic board can be iCloud unlocked and network unlocked although you would need to check which board you are buying. I would recommend selling your phone for parts and buying a new phone as a logic board would cost as much as buying a new phone.
このアンサーは役に立ちましたか?
Hello if i change my IPhone7 ‘s logic board, must I change the home button with it??
このアンサーは役に立ちましたか?
the homebutton is paired to the logic board from factory, only apple can fit a working replacement homebutton.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 59
Thank you. I was checking if it was new & unlocked or not. Thanks again
SamehMorcos さんによる
