メインコンテンツにスキップ
The tenth generation Corolla (E140) was released in Japan on 10 October 2006.
14の回答 すべて表示
malfunction in the vehicle's charging system
warning light details. Indicates a malfunction in the vehicle’s charging system
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1回答
選択されたソリューション
Hi,
Some things to check:
With the engine switched off (and the ignition key in your pocket) check that the belt that turns the car’s alternator is OK and not broken or is slipping (lack of tension) and not turning the alternator. Here’s a video showing a belt replacement in a 2009 Corolla which may be of some help.
Use a voltmeter to measure that voltage across the car’s battery terminals with the engine running.
Be safety aware when you do this.
Put the gear shift in Neutral (or Park) and apply the handbrake (emergency brake). Also don't wear any loose clothing that may catch in the belt or fans.
A good voltage measurement is between 13.8 -14.5V DC.
Anything less than the lower voltage will cause the battery not to charge and anything more than the higher voltage will overcharge the battery and could damage it.
If the voltage is less than 13.8VDC with the engine running and the belt is OK there may be a problem with the regulator or the alternator.
If the voltage is higher than 14.5VDC there may be a problem with the regulator.
この回答は役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
John Hester さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 66
今までの合計 253
