メインコンテンツにスキップ
AppleのMacBook Proラップトップはプロフェッショナルかつパワーユーザー向けの製品ラインです。MacBook ProシリーズはMacBook Pro 13インチ ユニボディ、MacBook Pro 15インチ、 MacBook Pro 15インチ ユニボディ、MacBook Pro 17インチ、MacBook Pro 17インチ ユニボディがあります。
15437の回答 すべて表示
I accidentally partitioned the source HDD: . Can I recover it?
I was hoping to copy the content of a 500Gb HDD onto a 500Gb SSD drive, using disc utility on a Snow Leopard OX. I intended to format the new SSD to Guide Partition Table, but I got distracted and accidentally partitioned the drive which was supposed to be my source. Is there any way to recover from this mega blunder?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
tôi cũng đã từng gặp giống trường hợp của bạn và chưa khôi phục được. nhờ các thành viên trong nhóm giúp đỡ
による
According to GoogleTranslate this means: I have also met your case and have not recovered. Thanks to the team members for help
による
She actually has a time machine backup, but immigration assistant does not seem to recognize it…I told her to boot via recovery drive and choose the time machine backup to recover from. On her time machine drive there are folders for the previous backups and one dmg file. Is the dmg file not the most recent snapshot of her old HDD? And can I not somehow drop this into her new SSD which has a freshly installed OS of the same type, Yosemite?
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
最も参考になった回答
Sure, just use Disk Utility and set it to one partition when you reformat it
この回答は役に立ちましたか?
スコア 1
コメント:
Mayer, maybe I was not clear: I used my own computer running OSX10.6.8 to transfer data from my friends's HDD to her new SSD via SATA to USB connections. I find that it is so easy to copy one drive to another in OSX10.6.8. But when I tried to format the destination SSD with a Guide partition table to make it bootable, I actually re-formated the disc on which the data was stored. So now the data has been erased from the source disc, because I partitioned it, her HDD ,instead of the destination drive, her SSD. Now I need to recover the data which was on her original HDD.
による
https://www.youtube.com/watch?v=OjYoNL4g...
Pray she has an external Time Machine backup or an iCloud account
による
コメントを追加
回答を追加する
Jurgen さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 37
