Tablet got wet - won't turn on
My tablet got wet. I have shut it off and taken it apart to dry. However, after putting it together the power button isn’t working. Do i need a new motherboard?
Water damage is very tricky. It can cause a wide variety of issues. If you can get a board for a decent price, then yes, more than likely the board is damaged and needs to be replaced. The battery could also need replacing. You may be better off investing that money into a new tablet, unless of course it’s much cheaper to repair.
このアンサーは役に立ちましたか?
ok so i think maybe you do and maybe you dont because have you tried putting it in rice and leaving it for a couple of days?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 2,757
My tab has dropped in water 2 years ago and it won't turn on can you help
Musab さんによる
