Ps4 Slim (CUH-2116B) Disc Drive
the disk drive in my ps4 1tb cuh-2116b isnt working… but i cant seem to find a replacement online could anyone help?
Unfortunately, I don’t have good news for you. Those disc drives are not really available anywhere. Your best bet is to just watch eBay. At some point one will probably turn up but it likely won’t be cheap.
I know that’s not the answer you’re wanting to hear but unfortunately, it’s the truth.
Any reason you don’t want to try and fix it?
このアンサーは役に立ちましたか?
hi, thanks alot for the reply… yeah cant find the drives anywhere…. so heres the problem, i stepped on my ps4 and the disk drive was working but made a grinding noise…. so i opened it up to find the metal was pushing down on the drive so i took the metal and bent it back to normal and it was working again as normal but then i went to put it back together and it stopped working … now when i put a disk in the drive it spits it straight back out …. and also every 5-6 seconds the drive sounds like its ejecting itself but does it very slow…. its nothing to do with the button or anything i checked i removed all the wires connecting the disk drive and still does it …. here is a video on what it does….. https://streamable.com/w60zu
i know the black legs are not all the way back thats becuase i didnt have the spring connecting to pull it back , but it still does it when the spring is in
if you could help it would be very very appreciated
jack
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 657
1件のコメント
jack
JackMck さんによる
