メインコンテンツにスキップ
Apple Watch Series 2は2016年9月7日に発表され、同年9月16日に発売されました。
132回答 すべてを表示
Apple Watch won't power up. I fixed it. Is it still Waterproof?
All reset efforts don’t work. Gets hot on the magnetic charger. Every once in a while the apple logo appears for a few secs then fades away.
Apple wants $275 flat fee to fix it. No way.
I feel comfortable taking it apart and replacing the battery. The question is: Is the problem with the battery? What are the odds it’s the battery and not something else?
Update (01/03/2019)
I followed the IFixit battery replacement video and successfully repaired the watch.
The old battery was significantly swollen. I was a little ticked that I found out Apple was repairing this problem in ser 2 watches, but failed to mentions that when I talked to apple support. They only wanted to charge me $270.
All the same the battery and adhesive strip were inexpensive, and after buying a Y000 tri-wing screwdriver, I successfully repaired the watch.
Here is my new question: How waterproof is the watch now? I used an adhesive strip, but it seemed so thin and flimsy I’m concerned at how waterproof the watch is now?
I saw another repair video that resealed the glass top with a B-7000” adhesive. Should I try something like that?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unfortunately, the only way to know is to try the battery. Be careful opening the watch as to not rip the force touch gasket. If you do, luckily its a 5 dollar fix. I would try the battery or maybe even try disconnecting then reconnecting the battery and see if that fixes it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chazz Lavely さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 169
