メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Weak GPS Signal Signal
Hello Everybody
I have a great problem with my iPhone 4.
I have it complet teardown and change the screen to a White One.
After rebuild, all working fine.
But the GPS Signal strengt is false, in Navigon the GPS Signal is "blinking" Signal ON OFF in one Second.
The GPS Accurancy is 65m an i have no solution, i have change all Screws, Emi Shield and Antennas, but i have no Solution.
Thank for our help.
Regards Patrik
Sorry for my bad english :D
I
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
I had this problem with my phone, but in my case the issue were the solder joints in the motherboard (PCB). I took it off and put in the oven for 7 minutes at 190 C, then, my GPS started workin' great(the oven's heat can melt and fix cracks in it).
But in your case, as the GPS was fine before disassembling it, my guess is that should be something connected wrong. You changed the screws, but did you put then in the right place? You can't exchange them, every screw has your own place. Check the Wifi/GPS antenna connection (close to the battery connector) too, maybe it's not well fixed. At the top cover of the phone are five screws, the 1.4mm Phillips (step 7 - http://tinyurl.com/43aon77) has a nut under it that use to fall when we make some movements with the mainboard. If that happens, the contact between the screw and the PCB is lost. Try to check it too.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you use your phone in the car so:
it may just be the frequency of the FM transmitter and not the device itself.
Try to changed the FM transmitter frequency and everything will work like a charm
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How to change the frequency of FM transmitter??
さんによる
コメントを追加
Check the top screw contact washer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Patrik Laube さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 8,873
