Apple AirPodsは2016年12月に発売されたワイヤレスヘッドホンです。
36の回答 すべてを表示
Airpod microphone part is broken, how to fix?
Hello everyone,
My airpods bottom part which is metallic is broken. What should I use to stick it back in? Would electrical tape be enough? Also, would that effect the charging?
Add a comment
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
I suppose electrical tape might work but that may affect charging. Unfortunately there is not much you can do as Apple is so restrictive about repair there is no way you could get any replacement parts for airpods. Even if you went to the Apple store I think they may say it is too small to fix. That unfortunately means you may have to replace your airpods completely.
Add a comment
Add your answer
cank will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 84
All Time: 204
