Unknown part (wire) in iPhone 5s
I was replacing back housing on my iphone 5s and I am curious what is this wire used for?
Thanks in advance
Vito
この質問は役に立ちましたか?
Thanks in advance
Vito
この質問は役に立ちましたか?
Vito, this wire is for the main cellular antenna. Without this cable, you phone will have 0-1 bars signal with your cellphone network. This part is unrelated to wifi, Bluetooth, or GPS.
Have you broken the cable? If so, do not worry as a new cable will come preinstalled on any replacement charger port. The charger port flex PCB is only a $10 part. However if you have damaged the round plug on the motherboard where this cable attached, you will need to bring the phone to a local repair shop. This would require a skilled to solder on a new antenna port.
このアンサーは役に立ちましたか?
+1...that's a better answer than mine :>)
Thanks. And no.... i haven't broken it I was just curious.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 53
