メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
64回答 すべてを表示
Why wont my battery charge?
i have a Dell Inspiron 1545 that wont charge, i have bought a new battery and charger (i left this thing in storage for over a year) and after i turned it on after a long time i get a message saying “ plugged in,not charging , i have tested the battery and charger on a relatives laptop and it works fine, what could be my problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Seems like the issue. could be with power relay/controller. Since it doesn’t deliver any current to battery, then it is most likely a faulty battery connector or somewhere in-between relay and connector an open end. (Assuming from the fact that AC still delivers power and your laptop runs just fine on AC alone.)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
i have been trying to search for a solution google and seen a big amount of people have the same problem( some cases go as back as 2006), so a problem with the plug of motherboard would be likely, i will see if i can pry the laptop open to examine for any visible damage.
さんによる
Plug of battery, I hope, you mean?
さんによる
コメントを追加
回答を追加する
Carlos Cervantes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 190
