My handset is in spanish. How do I get it set to english
How do I change langusges
Hi Anthony.
You need to hit the menu / select button on the handeset which is the top button on the right hand side of the handset and then hit the center button. This wil take you into the handest setup. Then scroll down to Handset Language ( in spanish this is idioma) this is the 7th option in the menu. From here you should be able to set the lanugae to english. The menu for you phone can be found here - https://www.101phones.com/content/pdf/un... and you will need pages 6 and 7.
Hope this helps.
Matt
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 22
今までの合計 1,082
