iPhone 5 display replacement
can i use a white display for a black display iphone 5
Yes, the connectors and flex cables are the same, you will just have a different color home button.
このアンサーは役に立ちましたか?
Yes. Only thing is that it will look even worse than it sounds with a different color home button.
このアンサーは役に立ちましたか?
Yes, the connectors and flex cables are the same, you will just have a different color home button. As a repair shop i would keep it the same color as the home button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 24
