Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
このアンサーは役に立ちましたか?
It might be much easier to just buy a new cable:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 107
1件のコメント
Hi. Maybe you could solder it but it won't be easy.
Csendes Csaba さんによる
