メインコンテンツにスキップ
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
76回答 すべてを表示
Why does my battery discharge so fast?
I now only get about 90 minutes use from my tablet before it needs recharging.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Dear friend Your Device Getting hot wile using?
さんによる
コメントを追加
1 件の回答
Aside from a faulty battery, software updates can also trigger your device to drain battery quickly.
There are three methods you can try out:
  1. Quit background apps then restart phone.
  2. Wipe cache partition on your Galaxy Note 8.
  3. Master reset/Factory data reset.
It is also recommended to monitor your battery usage regularly. By monitoring means viewing the estimated battery life based on how much you have used over the past week and likewise determining how much battery your apps are consuming.
Aside from managing battery usage for each app, there are some tips that can also help preserve battery life on your Galaxy Note 8.
Including:
Enable auto-brightness
Adjust screen timeout
Block accidental touches
Use Power Saving Mode
If your Samsung Galaxy Note 8 battery is still draining so quickly after applying all prior workarounds and battery-saving tips, then you should consider escalating the problem to Samsung Support for further recommendations.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian Smith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 237
