メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Google Pixelは、2016年10月20日に発売されたGoogle初のフラッグシップスマートフォンです。5インチのAMOLEDディスプレイを搭載し、32GBと128GBのストレージオプションがあり、Very Silver(ベリーシルバー)、Quite Black(クワイエットブラック)、Really Blue(リアリーブルー)の3色で展開されています。
After Battery Replacement, Screen Won't Work
I swapped out the battery on a Pixel recently, I was careful about heating up the adhesive enough and used the plastic pick to sever the adhesive. The screen didn’t crack when removing it. After i got the battery switched out, I put everything back together and turned the phone on. The phone vibrated, indicating that it had turned on, but the screen is black. I was careful not to damage any of the ribbons when pulling it apart. Does anyone know what this might be?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
ベストアンサー
The pixel has a very thin and fragile screen. It's very easy to damage the lcd without being able to see a visible crack. Also you could have knocked off components around the lcd connector. Or it could be a backlight issue. I would use a bright flashlight and shine it on the screen when you think it should be displaying and see if you can see anything. If you can then it's a backlight issue. If you have no backlight and no image then I would start looking at the board for damage. If you cant find any physical damage then I would get a new screen.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Whereabouts on the board would you check?
さんによる
コメントを追加
Having the same issue with the Pixel 3. Changed the battery but did break a piece of did the wireless charger and the cable for the finger print scanner. I planned on replacing them eventually but in the mean time my phone won't boot up with the new battery. Won't even tell me it's charging. Having a hard time loading software and idk why.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just changed the battery on my Pixel 4a. At first, when I pushed and held the power button, it would vibrate briefly, but the screen stayed black. I did that repeatedly- same thing. I thought maybe I had damaged the screen. When I held the power button for about 10 seconds (maybe longer), then the phone and screen finally turned on. Relief!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robert Black さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 39
今までの合計 4,404
