Why does my camera turn on but won't extend the lense?
My camera turns on but the lense won't extend. The screen tells me “turn the power off and on again" but I've done several times and the lense still won't extend? What do I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Kim Sanch there are a few things you can try to check on your stuck lens. Check on here. If none of that works you do need to take a closer look at the lens itself. Parts are difficult to come by for any repair of the lens assembly so you may consider replacing the complete lens assembly (part number is A-1268-104-A) .
このアンサーは役に立ちましたか?
It could be the lens motor as well..
have ave you powered it off,AND removed the battery…then hold the power button for 30 seconds? If not,please try this and report back.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 288
