Xbox 360 freezing up during game play after thermal paste replacement
Hi my problem is that about 2 days ago i replaced the thermal paste on my Xbox 360 s because my console was running very hot , after carefully taking it apart i saw that the old thermal paste was dried up so i replaced it with Noctua NT-H1 thermal paste, the problem is after carefully putting it all back together and making sure to plug every cable back in my console will randomly freeze during game play, sometimes during boot it also will freeze and/or there will be random pixelation on the screen but not as often. It will run fine for about what seems 10 minutes maybe a little more but then it will freeze no matter what game, I’ve tried formatting the hard drive and clearing the partition but nothing has worked yet. anyone know what the problem could be? any help would be nice thanks as i haven’t found any solution anywhere yet.
この質問は役に立ちましたか?
1件のコメント
Three possibilities. (A) You damaged something during disassembly/work/reassembly, (B) something isn't seated properly, like a fan connector or something, or (C) you didn't apply the thermal paste properly. I would probably go with "C" as a starting point. Disassemble, clean everything, and do it again.
Steve さんによる
